#1 Posted : Tuesday, 15 June 2004 9:48:22 PM(UTC)
Hi guys,
Does anybody know why a tacho in a HX GTS would read way to low. I have tried two different tacho's both original and have tried both the 6 and the 8 cylinder settings to no avail.
Is it possible that I am overlooking something. I am now running VL electronic but had the problem before changing to the new dizzy and coil.
Any ideas would be appreciated.
Cheers!
Anthony.
#2 Posted : Wednesday, 16 June 2004 2:36:41 AM(UTC)
Try connecting up a portable 'tune-up' style tacho, to eliminate any other wierd possibilities. As an aside, did you bypass the in harness resistor when you fitted the 12V coil?
#3 Posted : Wednesday, 16 June 2004 3:20:09 AM(UTC)
Hi Byron,
Firstly, thanks for your response. No I didnot bypass the harness resistor as I am unsure where it is. Do you know what it looks like and where aboutis it is located?
Cheers!
Anthony
#4 Posted : Wednesday, 16 June 2004 4:29:40 AM(UTC)
Hi Guys.
As Byron said check with an aftermarket test type tacho & compare readings.
I,ve seen this problem before when guys fit blue ignition to red motors, however I,ve done this conversion dozens of times & had no trouble & you
#5 Posted : Wednesday, 16 June 2004 8:01:33 PM(UTC)
Dr Terry. Found a wierd situation the other day on this exact subject. My HZ 1-tonner (ambulance pack) is a factory 308/TH400. It's currently got an aftermarket 12V coil with ballast resistor. Whoever installed it left the yellow wire on the coil, and ran
#6 Posted : Monday, 21 June 2004 7:22:10 AM(UTC)
The resistor wire is usually a fairly thick pink one. Unlike Dr. Terry I prefer to not use a relay because in my opinion it is another thing to go wrong and strand you. In situations like where you are fitting spotlights and have to run through the dipswi
This page was generated in 0.134 seconds.
