Hearing a lot of negative feedback for power steering on these cars, wondering where the problem lies, i drive fifties cars all the time and dont mind the feel but have never driven these models with it
Power steering on these models is a little light, but I would put it on again if I was to buy another HQ to WB.
warren
He was talking HG Warren. |
So whats your thoughts on the hktg style?
Sorry the g and q sometines get mixed up.
I have also had a HK which I converted to power steering and the feel, at first, was a bit awkward, after about 1/2 an hour you get use to it and its fine.
Warren
Cheers mate ill give it a go, thanks again
If you add some positive caster to the front end alignment, say around +1 to +1.5, it gives them better road feel.
Dr Terry |
Thanks guys, ill do exactly that
Joined: 2/02/2009(UTC) Posts: 567  ![Australia Australia]() Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 32 times Was thanked: 9 time(s) in 9 post(s)
Are there specific steering arms for power steering on HGs? If so you'd want to change to them.
Attn camry drivers. The accelerator is the skinny pedal on the right. |
No, the steering arms are all the same for HK-HG AFAIK, BUT they do use the 16.7:1 GTS steering box which does make quite a difference to road feel. Dr Terry |
Thanks Dr Terry. Once again an informative thread.
Chris |
