6 Pages«<23456>
#61 Posted : Saturday, 20 December 2014 6:08:20 PM(UTC)
Until HJ GMH didn't have a gearbox for the 308 that fitted within their Engineering guidelines for the power (engine) vs load (kg), hence the 308 wasn't optional in a cab-chassis in HQ. You couldn't even get a 253 in a tonner until eaerly 1973. They made the 308 an option on cab-chassis but only with BO6 as the TH400 was strong enough. BO6 was called an Ambulance pack but anyone could buy one, it was never intended that they'd all be ambulances.
I tried the same thing with Ford, I tried to buy a 1-tonne cab-chassis with turbo auto and no play. Also tried to buy an XR6T auto with the 3/4 tonne suspension, and I was going to turf the tub. Again no play.
castellan Offline
#62 Posted : Saturday, 20 December 2014 7:09:55 PM(UTC)
castellan
M22 is the same box as the M21
They could use the M20 in a 308 if 1st gear was to high with the M21.
The M22 is a hopeless ratio box with a 308 maybe but with a 173 it's ok sort of. the Trimatic is a good strong box stronger than the Aussie 4sp I would say but a cooler is a must have on any auto to last.
The T400 just killed the performance behind the 308 a hopeless dopy slush box in std form.
I wanted the Turbo manual as the non Turbo is way to gutless for me to drive and just the XR6 rear springs would do.
The dealer said it would be to powerful for me, I said what do you think I drive a camry. what's the difference in weight of a alloy tray to the ford tub, and who said I was using a alloy tray it could be steel with timber floor and I am sure that would be more than a tub. the thing was that the tub is just a bit to small for me and I hate plastic liners.
#63 Posted : Saturday, 20 December 2014 10:22:10 PM(UTC)
There was no V8 M22. And none of the Aussie 3/4spds or the trimatic were rated high enough to handle the GVW of a tonner and the torque of a 308. Once a piece of drivetrain reached its torque/weight limit it couldn't be used. This will be why the trimatic was replaced behind revised 308 in a Holden or Statesman post HQ, the new 308 would have seen the Engineered capacity of the trimatic exceeded.
I wanted an auto Falcon so I could tow 2300kg, but the stock XR6 rear suspension is not up to towing 2300kg (although Ford allow it). Once you get 230kg on the towbar and 2 x passengers you are either exceeding or close to exceeding the load capacity of the vehicle with the stock suspension.
1997 HRT GTS PILOT Offline
#64 Posted : Saturday, 20 December 2014 11:18:28 PM(UTC)
1997 HRT GTS PILOT
Originally posted by Dr Terry
Originally posted by 1997 HRT GTS PILOT
And it was one of the first Australian hand built VB prototype bodys assembled in 1977 so is now the oldest commodore in the country.
How early is the chassis number & VIN ? Or do they in fact have them stamped at all ?
Hi Dr Terry.
I had Vic roads do a historical archive search after I proved i was the current owner and they sent me all the vic roads records on it.
Victroads says it originally had no numbers stamped into the body, no chassis number stamped into the body but they do have the chassis number off the 1979 id plate recorded. I have also found a number 1 stamped near the driverside front floor footwell, Number 1 embossed and stamped on back of wheels and number 1 on a lot of parts.
The car or body is 5th month 1977 i believe as it has that chalked on it as well as number 1.
Im not sure when it was first assembled into a car but by the earliest dates of parts on it they range from 1976-77, I would say early 1977 at least.
Vic roads original rego information says car is 1977 even though the car has 1979 id plates and was first registered as a 1980 commodore.
It was given id plates in may 1979 when it was usef by Styling deptmt to do the VC sle. was first registered in June 1980
It was registered at Cheltenham police station with an engine number only and it says the car came from GMH salmon street Port Melbourne and it was secondhand.
It says where it was roadworthied and that a Holden dealer did the RWC and application for registration on behalf of a GMH employee.
I have all these details, marks on the car and papers to prove its the number one commodore prototype and had been used by the Design and Styling Department at Fishermans bend from 1976- 1980 when it was then sold through Balmoral motors to Christopher Emmerson who actually worked in the Design deptmt at GMH and was the one who was given the job of designing the VC sle. Balmoral motors was the agent used to roadworthy and register the car.
Alot of the parts on it date from 1976 -77 and then some major interior parts from 3rd month 1978 and then when it was used as the vc sle prototype it has 5th month 1979 parts and alot of parts on it look to be hand made.
The wheels are 1976 and have Number 1 stamped into them and also Number 1 is cast into them as well as X No 1 stamped.
The steering column is 7th month 1976 and has VA on it, not VB.
The structural pressings in the front are different to the production VB.
There is a lot of differences in the body that only someone that knows these cars would pick up on, on the outside it just looks like a VC commodore.
As you are well known on the forums i would like to send an invitation to you to come view the car if it would interest you. I am in Melbourne.
Can you send me your phone number so we can talk please.
Thank you.
Edited by user Sunday, 21 December 2014 6:22:54 PM(UTC)  | Reason: Not specified
#65 Posted : Sunday, 21 December 2014 12:34:23 AM(UTC)
1997 HRT GTS PILOT
Hi Dr Terry.
Victroads says it originally had no numbers stamped into the body, no chassis number stamped into radiator support panel but they do have the chassis number off the 1979 compliance plate recorded. I have also found a number 1 stamped near the driverside front floor footwell, Number 1 embossed and stamped on back of wheels and number 1 on a lot of parts.
The car or body is 5th month 1977 i believe as it has that chalked on it as well as number 1. It does have a chassis number on the 1979 id plate but that was never stamped into the body either.
Thank you.
Edited by user Sunday, 21 December 2014 6:21:55 PM(UTC)  | Reason: Not specified
detective Offline
#66 Posted : Sunday, 21 December 2014 6:30:35 AM(UTC)
detective
...Jeeez .. i love this stuff!...there isn't a single thing written in that last post that sounds too dodgy or way off track from what actually happened at GMH from even way back in the day to 1948...
...the first pilot Holdens never had a chassis OR engine number struck...those ten pilots were simply identified by their first registration numbers...MG 501 to MG 510.....cheers fellas
castellan Offline
#67 Posted : Sunday, 21 December 2014 9:15:46 AM(UTC)
castellan
The good old trimatic was behind the later WB Statesman and VH-K-L Commodore 5.0L
M20 Aussie box are in 6 cly and 253 V8 std
M21 Aussie box is a std 308
M22 Aussie box is std 1 tonne box, what did they use with the 253 ?
I would say that anything you tow should not exceed the weight of your car regardless of any claim. A mate bought the Falcon 1 tonne with an auto in it due to Fords claim you can tow more with the auto, the Falcon manual box must be weak then, but the V8 and Turbo box can't be that weak now can it ?
Moved to another thread - HK1837
#68 Posted : Sunday, 21 December 2014 5:04:55 PM(UTC)
1997 HRT GTS PILOT
Hi Dr Terry,
When you read my post can you send me an email with a contact number so i can talk to you?
I have read some further information that could point to the body shell of my car being a German made prototype.
It could have started life as one of three prototypes ordered by GMH A from Germany and sent to Australia in 1976.
I have found some parts that have what looks to me to be writing in German on them.
Do you have any idea if this fits in with the time line of my cars build?
There are some major structural differences to the front chassis and it may have had VB front panels grafted on, im just not sure as the body is very roughly put together in my opinion so hard to tell if its just rough panel fitment or because a different front has been added, panel alignment is off the scale under the nice exterior.
There is no doubt in my mind the car is significant and is a prototype.
I have been laughed at and name called about being so persistent with this car and that my attitude is bad but all i wanted to get was someone to listen to me and that i had noticed a lot of weird things about this car. I was told by a Commodore person it was just a test for Shadow tone, but after receiving the documents from Vic roads it leaves no doubt that the car is a prototype, and number 1, just which number one is the question. Was it number 1 German prototype shell? Or Number 1 Australian shell? The only thing i know for sure is it was the first VC SLE Prototype styling pilot car but what was the car used for prior to 5th month 1979?
I really need to send you photos of the markings and all the parts etc, I now realize you are in NSW and not Melbourne.
After being laughed at when i told some other commodore site what i had i just don't want anything to do with those people or want them anywhere near my house or this car.
Do you come to Melbourne at all? If so maybe you could arrange a detour to look at it?
Failing that, do you know anyone reputable in Melbourne that i could trust?
Thanks in advance.
Edited by user Sunday, 21 December 2014 5:32:11 PM(UTC)  | Reason: Not specified
#69 Posted : Sunday, 21 December 2014 5:22:22 PM(UTC)
I doubt it would be one of the cars sent to Australia from Germany, as discussions with Leo over the years reviewed that the Commodore was completely redesigned here as the test mules simply fell part.
The Australian built prototypes may well have used a lot of the bit sent over in those original Opels, which would explain the German writing.
When you look at development times etc a couple of years before release is not much time for a motor car. When I have had the opertunityy to talk to design staff in the past, they have commented about when people talk to them about the new Holden they see it as old as they have normally been working on the next Holden for some time.
Warren
#70 Posted : Sunday, 21 December 2014 7:51:24 PM(UTC)
1997 HRT GTS PILOT
Hi Warren,
Would it be a safe bet, due to the car not being registered until June 1980 it spent its entire time in the Styling department at GMH Fishermans bend as some type of example for fitting and testing of parts prior to being build plated in May 1979 and used as the VC SLE styling prototype?
Did Leo ever mention the prototype VC SLE when you talked?
On another forum a bloke reckons the VC SLE press car went to Pattersons, have you heard of this? Balmoral in Cheltenham were authorized to road worthy and register the car on behalf of new owner, have you heard of this type of thing happening before?
Registration application was done at police station and says it was picked up from GMH salmon st Port Melbourne.
A few things that puzzle me are why the registration authority had it down as a 1977 and also had the 5th month 1979 compliance plate chassis number snd still registered it as a 1980 commodore?
What are we missing here?
Did GMH pull some sort of "shifty" so they could sell it? register it for the employee?
Why get Balmoral to road worthy it and register it on behalf of employee?
Who would have approved the sale?
I know its a lot of questions to try and answer but the more i unearth , the more questions arise.
Thanks in advance.
Edited by user Sunday, 21 December 2014 7:53:53 PM(UTC)  | Reason: Not specified
#71 Posted : Sunday, 21 December 2014 8:09:40 PM(UTC)
1997 HRT GTS PILOT
Ok interesting Sunday morning!
I've just had word from Chris Emmerson via email and i have organized to talk with him on the phone at 11am.
He did confirm some information in his email:
Quote:
"What you have there is the forerunner of the VB commodore that was later used as the prototype VC Shadow tone car".
Words in writting (email) from Chris Emmerson himself the actual designer and now absolute undeniable proof of history and provinance as the VB Foruner (prototype) and the VC Shadow tone prototype.
Now I can find out the rest of the cars history at 11am, will hopefully be able to fill in a lot of missing gaps.
Thanks to everyone that helped out and didn't shoot me down and say im an idiot to think this car was the VC Shadow tone prototype car.
That now leaves a big dent in the other forum members story that the car went to Pattersons.
I will definitely be asking Chris about this.
Keep you posted!
Edited by user Wednesday, 24 December 2014 4:04:44 AM(UTC)  | Reason: Not specified
#72 Posted : Sunday, 21 December 2014 11:27:44 PM(UTC)
Originally posted by 1997 HRT GTS PILOT I now realize you are in NSW and not Melbourne.
Yes, Dr Terry is Sydney based, and quite a few forum members are personal friends of his, myself included.
Originally posted by 1997 HRT GTS PILOT Do you come to Melbourne at all? If so maybe you could arrange a detour to look at it?
Would he want to? Like you tried to do with me, and then totally ignored all contact when my trip to Melbourne was imminent?
Originally posted by 1997 HRT GTS PILOT I really need to send you photos of the markings and all the parts etc,
I'm still waiting for what you promised to email me.....
This is why I haven't bothered to post any replies to any more of your questions, despite being able to answer a number of points in question.
All of your requests seem to be for your own personal gain (possibly financial, based on the other cars you have bragged about buying for 1/3 of their true value). You have yet to share any pictures (despite it being very easy to use photobucket and the like) and you have used different names too - are you Damo, or are you Phil, or some other name?
There are other forums that make financial gain from sponsorship and advertising, for a select number of their "owners" or key posters. Forums like those that you criticise.
This forum, on the other hand, is very different. Yes, it may well be funded by Rare Spares (keeping it truly free of charge for us) but none of the honest, knowledgeable guys here on this forum are doing any of this for any money or glory - it's all off our own back, gratis, for the passion of the vehicles and what they stand for.
#73 Posted : Sunday, 21 December 2014 11:34:20 PM(UTC)
...double post.....
gm5735 Offline
#74 Posted : Sunday, 21 December 2014 11:42:43 PM(UTC)
gm5735
Commodorenut, I wondered how the authentication trip went. That answers that one!
#75 Posted : Monday, 22 December 2014 12:03:37 AM(UTC)
1997 HRT GTS PILOT
I just had a very interesting hour long conversation with Chris Emmerson, the designer of the VC SLE Shadowtone prototype.
Chris has offered me some of his original sketches of the VB VC commodore and invited me to his home in country Vic.
Where do i start. ... First there has been a lot of untrue stories and rumors about me and my car on another forum. Yes, I got upset when a guy insulted and name called me on a public forum and that forum then basically called me a liar and an idiot for all to see. I apologize for my behavior, it too was most appalling and I lowered myself to their standard and got my back up but I just don't like to be ridiculed and made to be a liar. I am NOT.
Now as i have said, i have all this from Chris Emmerson himself, you can take it or leave it but i will be going to see Chris and he said he will be signing my car as the designer and he will be staying in contact via email in the interim with as much information as he can remember.
This is how Chris told it to me:
Chris came to Melbourne from Qld in 1968 and started working as a designer for GMH. Worked for GMH from 1968- 1981.
My car was the first Australian VB prototype body and did not have any id tags fitted or chassis number stamped into the body when first assembled.
I believe i have strong evidence to back up my theory that this car was originally registered prior to 1980. Possibly has remains from one of the three prototype cars sent from Germany and was modified " built " into the first Australian VB. Evidence i have found on the car points to it having had possible VC front structural panels welded on to it, i presume during the mid 1979 VC build.
I have obtained further information from Vic roads and now have evidence to back this claim up, the car was definately registered prior to 1980, not first registered in 1980 as i was lead to believe. This would also explain how Leo Pruneou was able to use it as his personal transport from mid 79-80. Vic roads have sent me out earlier registration documents from the Vic roads archives which say it was first registered as AC#-### at least two years prior to its June 1980 re-registration. I believe it was given a full re-build after its testing days with new body panels etc and re-painted in early 1979 before it was given to Chris Emmerson to design the VC SLE Shadowtone and was a GMH internal car and kept at Fishermans Bend Port Melb in the Styling and design studios from 1978 through to 1979. Vic roads papers also show it to have a 5 litre and manual at one point prior to 1979.
Chris said it was always at GMH Port Melb in the Design and Styling studios between 1978- 1979 and then used by Leo and later stored in the outside yard prior to mid 1980.
It was a running car when allocated to Chris during the VC SLE styling period early to May 1979, i asked Chris if he was sure about this, he said "Oh yes" it was a running car and was originally painted in the "woodshop" next door to the Design Studio where it was kept.Yes, the woodshop, where they had a small spray booth set up. Chris said it was the only complete VB in the Studio at that time and recalls it was originally all over black with NO tags when he started work on it and it became the only Black and Silver painted car at that time and had build and compliance plates fitted in May 1979 to represent what it was at that time, that was two years after the car was actually manufactured. Chris used the words "Forerunner to the VB" on numerous occasions, which I believe in layman's terms to be " pre VB production or simply prototype" Correct me if I'm wrong. I have spoken to Chris again and asked him if he knew of the car prior to 1978- 79 and he said he didnt but was told by Management it was the first Prototype VB and thats why he refers to it as the VB forerunner.
Chris said management allocated him the car as they wanted the VC SLE to be something more than what the VB SLE was, when they saw the shadowtone car after Chris had finished it they said to him "We love it". Chris also designed the Red and Blue pinstripes that were manufactured by Calta Brands of S.A. and he also applied the stripping.
Chris also designed a four round headlight front which he ssid he will give me sketches of.
Interior Design which was next door to the Torana Studio designed the VC style interior.
Leo Pruneu was the boss of Styling and Chris and Leo got on quite well.
Chris also recalls the GTRX and worked on it and drove it at Lang Lang, it was white and later painted silver and SLE wheels were fitted.
This is where it gets interesting, on another forum i was laughed at and told the VC prototype was not my car because that car was a pre build that went to Pattersons, that is RUBBISH!
Chris Emmerson has told me and i will quote "Your car was the only prototype in the Design and Styling studio at that time May 1979" "Your car was used as the VC prototype Shadowtone car and was allocated by management and was originally the forerunner of the VB commodore, "PROTOTYPE". It was the car shown to management and the car that was photographed and did NOT go to Pattersons but went to Balmoral as a dealer display around March or April 1980. Any other car that peolpe are talking about would have been part of a batch done very late 1979 to show dealers, your car is NOT one of those as they were pre production. Balmoral later had the car Road worthied and registered when it was sold.
It gets even more interesting now because i have heard people on the other forum say how they spoke to Leo at car shows and he says they made a batch of them and no prototype, again RUBBISH! There was a handfull only in late 1979 and there was one prototype in the Studios, my car.
This is the really interesting part and a little confusing but this is how Chris said it:
I asked, What was my car doing sitting around up until early 1980 and where was it stored at GMH? Chris said quote: "Leo took it". I said what do you mean? He said "It was Leo's". He couldn't tell me how he was able to drive it as it was supposedly unregistered and he can't remember if it had rego plates but Leo Pruneau was using it from around the time it was finished mid 1979. Chris said it was sitting in the outside storage yard with a bunch of other oddball cars like a Buick, Corvette etc when he saw it up close again early 1980. Vic rego archives show the car as a 5th month 1977 build with 5th month 1979 compliance plates and first registered on 6th month 1980 as a 1980 commodore, how could this be and how was Leo Pruneau driving it around with no rego? I believe it was registered but with the original Engine number only, NO Vin or Chassis number. Chris doesn't know how it was registered as a 1980 commodore because Balmoral organised the registration and purchase was organised through GMH management in June 1980 and as Holden dealer Balmoral motors had the car they were used to organise the RWC and registration.
This is all out of Chris's mouth. Take it or leave it , I'm not here to argue or get my back up anymore, I have nothing more to prove as i have it all from the guy that worked on its mouth and he has offered to email me everything so I have it in writing so to speak and give me the original sketches and sign the car Chris Emmerson VC SLE designer.
That's about all i want to say about the car right now and Chris right now.
Again, I'm not here to argue, you can take it or leave it or just wait till i work out how to post photos and then make your mind up.
One thing is for certain, the car is the first Australian VB prototype body assembled and its the one and only VC SLE Styling Prototype.
I will update this thread as new information comes to light or if information posted is found to be inaccurate.
A Merry Christmas to all.
Edited by user Tuesday, 30 December 2014 1:34:23 AM(UTC)  | Reason: Not specified
#76 Posted : Monday, 22 December 2014 12:17:17 AM(UTC)
1997 HRT GTS PILOT
You tell me what financial gain I have in this? Ive never tried to sell it and have no intention of selling it.
Yes i have the number one HSV VT GTS prototype. Authenticated by HSV and others and I am a member of the HSVoC.
What are you trying to say? The GTS was front cover of Motor magazine and Wheels magazine multiple times 1997- 98. Its a fully documented car with full provenance and history. Yes it has an interesting history, so what, does that make me a liar? I certainly hope not. Just to set the record straight, did you call me? If you want to catch up for coffee and look at the car i will extend my hand but at the time and niw again there are some really stupid people who like to stir the pot and get my back up.
I'm not interested in providing anything now because i have all the proof i need and I know what the car is and i was right that it was the VC Prototype, I just didn't know it was in fact a much earlier car before that.
Sorry if I've come across as a tosser and sn arsehole, that's not how my family and friends see me.
Maybe when this dies down you will take me up on that offer if a coffee and chat while looking at the car.
Cheers, Damo.
#77 Posted : Monday, 22 December 2014 12:49:13 AM(UTC)
1997 HRT GTS PILOT
My 1997 VT Prototype GTS is well known on forums and there are photos of it at Sandown raceway three months ago and numerous other photos.
Nothing to hide there.
No financial gain, I paid 20, 000 big ones for it now you tell me how i got it for nothing.
See that's what i mean, all talk and innuendo.
That's why i don't want certain people at my place.
Seriously tell me how im in it for financial gain?
I love the history behind these cars and I'm one person who goes above and beyond to prove a cars provenance and i dont give up on missing information until i find it or get confirmation from a person who was there or has the answers.
I traced back and have personally spoken to all but one of the GTS prototype previous owners. And the guy that bought it off the guy John Harvey sold it to said and confirmed everything again. It was the first HSV VT prototype and it was never supposed to be sold. But John Harvey offered it to his mate and the car was saved.
Phil Duncan who you might know of in the racing world told me that and he was the second owner of it.
He even confirmed it has VN Group A heads and was stamped by HRT on the engine block. He even sent me the original compendium which was never passed on to the guy he sold it to. Phil knows im no mug, I thank you Phil and your son for looking after me.
Cheers, Damo.
Edited by user Monday, 22 December 2014 1:24:10 AM(UTC)  | Reason: Not specified
detective Offline
#78 Posted : Monday, 22 December 2014 1:32:41 AM(UTC)
detective
...i'm still luvin' all of this info and banter and i can understand the passion 1997 HRT has for his chosen interest...it's just that the pilot/prototype/pre-production/design studio stuff etc. etc. will always have a sense of mystery and voodoo witchcraft about it LOL...
....1997 HRT would do well at this point to try to put up pics and numbers information so we can all enjoy his discoveries and resume our gentlemanly dialogue...
...oh and PS .. my name is Phil, but i'm not 1997 HRT GTS PILOT and have no association to him....cheers fellas
#79 Posted : Monday, 22 December 2014 3:32:18 AM(UTC)
Firstly,
Leo is a great man with lots of information, however as I stated earlier, the styling department are working years in advance of production and sometimes when you talk to Leo he gets the times mixed up. You really need to know your stuff when talking to him. It would be quite possible for those who spoke to Leo about your car to have been given some information, and from this come to a conclusion that was not quite right.
Compliance date is the date the engine goes in and this date should be on the compliance plate on the car.
The car may have been registered at one stage and then unregistered and sold that way. I have documentation on some cars that are sold to dealers as unregisterd and even unregisterable.
Would love to see pics of all the plates and the car.
Warren
#80 Posted : Monday, 22 December 2014 5:51:42 AM(UTC)
1997 HRT GTS PILOT
Hi Phil and Warren.
I have been trying to work out for past hour how to load photos.
Any hints?
Cheers.
Guest (17)
6 Pages«<23456>
This page was generated in 0.161 seconds.
