Reno Offline
#1 Posted : Thursday, 20 November 2014 4:04:46 AM(UTC)
Reno
After checking the oil level of our 4.1 alloy head motor and attempting to insert the dipstick back into the dipstick tube it would not go in fully - it seems that something is preventing it from going back ?? never experienced this problem previously - can someone advise how this issue can be rectified so that the dipstick can be pushed back to its normal position ? Thanking you your reply
#2 Posted : Thursday, 20 November 2014 6:17:46 AM(UTC)
Pull the dipstick back out, rotate 90 degrees and try re inserting it. Repeat until it goes in.
That's what I used to do with mine from memory.
Check that the dipstick tube has not come out of it's hole in the block if rotation fails to work.
Reno Offline
#3 Posted : Friday, 21 November 2014 10:50:06 PM(UTC)
Reno
Thanks for the suggestion - problem fixed
#4 Posted : Saturday, 22 November 2014 12:17:37 AM(UTC)
What was it?
Guest (5)
