David Offline
#1 Posted : Tuesday, 2 December 2014 9:14:27 AM(UTC)
David
Hi Gents,
Are there any reasons why I should not use a polytarp to cover a car stored in the open? (Using the better stuff that lasts 12 months)
What would be best to cover it?
#2 Posted : Tuesday, 2 December 2014 4:16:00 PM(UTC)
Even in the lightest breeze, it will rub the paint & cause scratches.
There are commercial covers that have a soft lining, but even they say they are not to be used for long-term storage. The waterproof ones cause sweating on the underside due to the temperature differential as the day heats up & cools, and even the "vented" ones suffer from this. In only 2 weeks an expensive cover caused the paint on the roof strips on the in-law's WK Caprice to start peeling - that was caused by the heat & humidity that the cover traps.
I have the same dilemma, and after looking at the various options, the solution for me is to build another garage.
#3 Posted : Wednesday, 3 December 2014 12:47:08 AM(UTC)
I've never had an outdoor cover but I have several CoverCraft indoor covers and they're good quality items.
This ones outdoor - http://www.covercraft-pa...fit_weathershieldhp.html
HKBro Offline
#4 Posted : Thursday, 4 December 2014 6:37:28 AM(UTC)
HKBro
I have used an Autotechnica cover for a few years in outdoor service. They are expensive as car covers go but well worth the money. However the UV gets them in the end.
the Blue Light Offline
#5 Posted : Friday, 5 December 2014 5:41:06 AM(UTC)
the Blue Light
How hard would it be to rig up some kind of removable frame you can set up around the car to drag a tarp over and keep it away from the paint work to allow drying / cooling? Might be an interesting project.
#6 Posted : Saturday, 6 December 2014 9:29:41 AM(UTC)
Not sure if they're still around, but you used to be able to buy "portable" garages that are basically just that - a steel tubular frame, and a tarp-like white plastic that goes over it. Similar in design & style to an early cheap portable gazebo, but with sides as well. Around 6m long by 3m wide. I have one in the garage that was given to me. Seeing how easily those gazebos become a hazard in medium-strength winds, I won't risk putting it up.
peter_flane Offline
#7 Posted : Saturday, 6 December 2014 10:37:06 PM(UTC)
peter_flane
You can cheap portable gazebo's that are 3m x 3m, and A friend got one that was a double, so 6m x 3m. He tied the corners down real well, and it lasted 10 months in the sun
