J3Bedford Offline
#1 Posted : Friday, 17 April 2015 2:41:14 PM(UTC)
J3Bedford
Just wondering if there's places that still sell the rebuilt exchange engines like Repco use to and were in Qld.
Edited by user Sunday, 19 April 2015 10:05:43 PM(UTC)  | Reason: Not specified
J3 4Ton Bedford Truck
JBM Offline
#2 Posted : Friday, 17 April 2015 7:14:46 PM(UTC)
JBM
Higginbottom still do them but they give you a 60 thou over bore. If you want to keep your block going a bit longer with a particular oversize go to a smaller shop like LW Parry at Arncliffe (I'm not sure if they are still there). But one is going to be more expensive than the other.
James
J3Bedford Offline
#3 Posted : Sunday, 19 April 2015 10:05:10 PM(UTC)
J3Bedford
I had a look at the sites you recommended but were in Qld.
JBM Offline
#4 Posted : Sunday, 19 April 2015 10:32:19 PM(UTC)
JBM
Where abouts in qld are you? This may be an obvious thing to do but have you tried your local Yellow pages?
J3Bedford Offline
#5 Posted : Wednesday, 22 April 2015 10:51:30 AM(UTC)
J3Bedford
Were in Bundaberg but would be willing to travel to collect and we've searched using the Google and Telstra yellow pages and can't find anything suitable relating to exchange engines. What I mean by exchange is where you take in your worn engine and they give you a completely rebuild engine in exchange for your engine and a hand full of dollars.
Edited by user Wednesday, 22 April 2015 10:53:22 AM(UTC)  | Reason: Not specified
#6 Posted : Wednesday, 22 April 2015 4:34:02 PM(UTC)
I don't think there's the market for that sort of service anymore, with even less demand in regional areas.
When locally made big sixes were common on our roads, Repco, Higginbottoms, Gem etc could afford to run 10-12 engines through at a time, put them on the shelf, and offer them on an exchange basis - reasonably economically. You could even source popular small car engines this way too - Gemini 4 cylinders, Corolla 1K/3K etc, 16R/18R/20R - because these cars were sold in decent numbers, unlike the pattern of the last 20 years where there's at least a dozen different makes in just about every segment, and hundreds of model options. Even the top selling vehicle in Australia accounts for less than 4% of our total new car market volume. A far cry from the days of the big 3 accounting for 60% or more of sales, and one model holding almost 20% of all new car sales.
Since those days where exchange engines were common, a number of things have worked against that industry, including:
1. Engines are lasting a lot longer, often the acceptable serviceable life of the car.
2. Diversity of the cars on our roads - long gone are the days when 50% of the national fleet were 6s & 8s from the big 3. They'd have to carry a much wider range of engines, and hold a lot more expensive stock, which simply isn't viable.
3. The popularity of cheap "wrecker" engines - not only for the Jap & other Asian makes, but for locally made stuff too - where you can buy a runner with 3 months warranty, for less than 1/6th the cost of doing a reco, and for most this is normally acceptable, referring back to point 1. You can buy a good running Commodore V6 from the 90s for less than $500. It would be at least $3K to reco one when you add in machining cost, labour & reasonable quality components. V8s are under $1000 for a runner (engine only, no accessories).
gm5735 Offline
#7 Posted : Wednesday, 22 April 2015 11:03:59 PM(UTC)
gm5735
If it's an exchange reco engine you really want, and for a fairly common vehicle, HM Gem are alive and well and tell me they have over 1000 exchange engines in stock. Their distributor in Bundaberg is your local Bursons outlet.
As Commodorenut says, it isn't your cheapest option. For example, a VN V6 long engine is around $2300.
Their phone number is 1300 767 040, or contact Bursons.
Guest (9)
