Ausjacko Offline
#1 Posted : Saturday, 4 July 2015 8:53:18 PM(UTC)
Ausjacko
Anyone have a photo of the linkages as they are connected to the box and shifter for a HT edit 350 Monaro they are willing to share?
My reverse rod seems to be too close to 3-4 and I am reading there may be a difference between the HK and the HT rods.
Jacko
Edited by user Saturday, 4 July 2015 8:57:04 PM(UTC)  | Reason: Not specified
gm5735 Offline
#2 Posted : Saturday, 4 July 2015 10:22:41 PM(UTC)
gm5735
You are correct. The HK shift rods are of different lengths compared to the HT shift rods, and have different bend locations. This is because they pass under the transmission mounting cross member on HK, which is bolted to the floor pan, compared to HT where they pass between the cross member and the floorpan. On HT the cross member is mounted to extension rails on the front subframe.
Ausjacko Offline
#3 Posted : Sunday, 5 July 2015 3:19:35 AM(UTC)
Ausjacko
OK, no photos, I will settle for a diagram showing the linkages on the drivers side if anyone has them. The manuals I have show the 4spd linkages on the drivers side-what the?
gm5735 Offline
#4 Posted : Sunday, 5 July 2015 4:04:54 AM(UTC)
gm5735
Ian, I've sent you a pm.
Ausjacko Offline
#5 Posted : Sunday, 5 July 2015 6:22:18 AM(UTC)
Ausjacko
PM replied to- thanks.
