#1 Posted : Tuesday, 10 February 2004 6:55:30 AM(UTC)
does anyone know how i can make my car as cheap as possible to run, it's an xe panelvan fully standard on gas with original carby, i do alot of kms up and down the hwy every day, so even a little mod would make the difference any suggestions, thanks.
Eddie, Vic
#2 Posted : Tuesday, 10 February 2004 9:12:29 AM(UTC)
You could try a higher ratio diff(depending what you already have). A 2.92 or even a 2.77 would cut revs on freeways,etc. Even new spark plugs, higher tyre pressures(check your tyres max. pressure first),clean air filter and even a thinner oil can all hel
#3 Posted : Tuesday, 10 February 2004 11:37:38 PM(UTC)
The diff gears is avery effective way but if it's aquestion of money you could always put larger diameter tyres on the rear as this will give the same effect as changing the diff but much cheaper.
A little trick that we used to do to friends cars (with
#4 Posted : Friday, 19 March 2004 3:38:05 AM(UTC)
If its not a five speed, you might want to consider changing to one
#5 Posted : Wednesday, 29 September 2004 11:57:17 AM(UTC)
take out the engine los
