#1 Posted : Friday, 20 February 2004 9:16:05 AM(UTC)
Have a ZD Fairlane running a c10, 302 Windsor (approx 145000 miles).
Overheated 2 wks ago (went to about 3/4 on temp gauge).
Very unusual for this car considering it always sat at about 1/4.
Had radiator inspected and cleaned out.
Flushed the engine water compartments totally and got rid of all the dirty water etc.
Installed a new thermostat (77 Deg)
and a 7 blade flex fan. It also has a shroud in front of radiator.Added coolant etc
Whilst in traffic the temp stays at 1/4 until I stop for traffic lights or in heavy traffic.If I put it into neutral at the traffic lights the temp stops rising (obviously revs are higher water is getting around)
Went on a highway drive to Traralgon the other day and it was fine until I started to flaw the car whilst overtaking etc and doing about 60-70 mph on the trip.
The engine temp started to rise slowly at that constant speed and it went just over the 1/2 way mark on the gauge.
As long s I can remember the car never did this. Was always running cool.
It doest use much oil (it maybe needs a top up 300-500ml every 2 to 3 months).
Oil is pretty clean (changed about 2 weeks ago)so it might not be a headgasket.
Water is not missing from the coolant system as I check it everyday and it sits about 1/2 thumb under the cap.
Is this normal for 302 Windsors
ie to generally heat up.
Any feedback/suggestions will be appreciated
Chris
#2 Posted : Friday, 20 February 2004 9:31:31 AM(UTC)
Check the water pump. Sounds like the waters not flowing correctly.
#3 Posted : Friday, 20 February 2004 10:30:34 AM(UTC)
Yep, water pump is where I would look next too. The impeller fins that move the water might have corroded.
#4 Posted : Saturday, 21 February 2004 5:42:28 AM(UTC)
Thanks alot Paul.
I'll check the water pump
Appreciate your prompt reply.
#5 Posted : Saturday, 21 February 2004 5:43:33 AM(UTC)
Thanks Brenden for your reply
Appreciated.
Will check water pump
#6 Posted : Sunday, 22 February 2004 7:30:37 AM(UTC)
has it got an auto transmission cooler, i've had your problem many times, as i tow heavy loads most of the time, what happens is, the auto fluid is cooled through the radiator and if your pulling hard along the road your auto will get very hot, very quik,
#7 Posted : Thursday, 29 April 2004 5:48:40 AM(UTC)
hey same proberlem in a ZD here but a 351 celeveland, new water pump same thing, flushed radiator same thing, new thermo sammme thing, and new 7 blade fan n yer same thing, but i got this thermostat which brought it down to half itss called a tridon Hi-Fl
#8 Posted : Wednesday, 25 August 2004 4:39:09 AM(UTC)
Transmission wear and torque converter wear can generate heat, especially in hard acceleration. A heat probe or infra red heat gun used during a stall test will see how quickly the trans temp rises. The stall test will also test the basic condition of th
#9 Posted : Thursday, 4 November 2004 4:26:40 AM(UTC)
I have a Zd and yeah mine genrally sits around 1/4 to half but never goes above. (302ci)[email protected] (New Zealand)
Guest (5)
