#1 Posted : Friday, 16 April 2004 8:17:11 PM(UTC)
Hi guys I have a XC 351C and am having a knocking problem when accelerating medium to hard. Light acceleration is ok. I checked the initial timing and it seems to be a bit high about 12 degrees the problem is when i go to retard it (even a little bit)the engine doesn't seem to like it. It runs rough and wants to stall. Any idea why it is doing this?
#2 Posted : Friday, 16 April 2004 11:19:24 PM(UTC)
you could try speeding the idle up a little.
#3 Posted : Saturday, 17 April 2004 9:39:22 PM(UTC)
Factory setting between 6-10deg depending on what year the cars made.
Try 6 deg and up your idle as Bill has already suggested.
#4 Posted : Sunday, 26 December 2004 4:03:54 PM(UTC)
#5 Posted : Monday, 4 April 2005 6:10:51 AM(UTC)
Try adjusting your idle also maybe you distributor is out a tooth.
#6 Posted : Tuesday, 5 April 2005 9:11:30 AM(UTC)
don't forget to disconnect the vac advance and plug it off......I've seen many who forget to do this.
