#1 Posted : Tuesday, 29 June 2004 6:02:51 AM(UTC)
I just got offered an EB 25th anniversary wagon on gas for$1500.00,it's in really good condition but has noisy lifters and needs the rear main seal replaced,other than that it drives great and has been well looked after.However the fella selling it says that the noisy lifters are due to a plastic component in the lifters having worn out and that this is common to these engines.Is this true,as i can easily fit some new lifters but i've never heard of this and don't know if it's bullshit.Also are the EB's a decent sort of car.Any replies most appreciated.
#2 Posted : Tuesday, 29 June 2004 5:32:19 PM(UTC)
Depends on how warn they are i hear. The rebuild kits are $120 for the set of replacement plastic tips. New lifters are $120 EACH! I have the same problem with my ED and the mechanic I saw about it said he did nt want to pull the rocker gear off to fix i
#3 Posted : Tuesday, 29 June 2004 8:02:05 PM(UTC)
The EB is a good car & in my opinion the EB2-ED are by far the best of the E series. The lifters could be a problem I had them replaced in my EF when it was 6 months old (Warranty of course). Having said that my EB2 has done 390,000 with it's original
#4 Posted : Thursday, 1 July 2004 9:01:22 AM(UTC)
Thanks for the replies fellas.I was told the car is an EB,it has 30th anniversary badges and is silver.It sounds like the lifter fix is what i was told then,the kit for $120 sounds about right,but $120 a lifter is pretty steep,but then again i've heard VL
This page was generated in 0.083 seconds.
