#1 Posted : Thursday, 5 August 2004 4:55:52 AM(UTC)
EA 6 CFI manual, starts but appears to run on 5 and very rich. Rev it up,and it clears after 10-15 secs.
Plugs,leads,cap,rotor,compressions all OK. Swapped MAP sensor and TPS as per computer codes but no better. Any ideas????
#2 Posted : Thursday, 5 August 2004 5:34:02 AM(UTC)
is it mpi or throttle body?it may be an injector
#3 Posted : Thursday, 5 August 2004 11:09:18 PM(UTC)
Centrepoint throttle body. I can't understand why it only affects No5.
#4 Posted : Friday, 6 August 2004 6:17:52 PM(UTC)
1 injector is for low rpm the other is for high rpm.maybe its the low rpm injector?
#5 Posted : Friday, 6 August 2004 10:35:10 PM(UTC)
It sounds a bit like a small corroded hole in the head on number 5 cylinder or a dodgy head gasket. have you had any tests done to find out if it's pressurising the cooling system? is it using water?
#6 Posted : Friday, 6 August 2004 10:35:26 PM(UTC)
#7 Posted : Friday, 6 August 2004 11:27:17 PM(UTC)
Compressions are all OK,does not use water,oil is clean, and it ONLY misses{no 5} for up to 20 secs on first start of a morning. Once it clears it runs sweet all day. I've only had the car 3 weeks and don't know it's history. Talked to a couple of mechs a
#8 Posted : Friday, 6 August 2004 11:28:28 PM(UTC)
#9 Posted : Sunday, 8 August 2004 1:52:34 AM(UTC)
I reckon it's oiling the no5 plug and then decarboning it after a short drive. Does a blow a tad of blue smoke when it 1st starts in the morning (cold start)?
#10 Posted : Sunday, 8 August 2004 2:54:09 AM(UTC)
My EA had the same symptoms which gradually progressed to a point where I had to take the head off and have it welded. If you've only owned it for a few weeks I would strongly suggest that you keep a close eye on your coolant levels. What point does the
#11 Posted : Sunday, 8 August 2004 2:54:22 AM(UTC)
#12 Posted : Monday, 9 August 2004 3:58:11 AM(UTC)
Temp guage sits on normal, No 5 plug was taken out and checked before start and inspected. The only visual is that it appeared to be spotless, Refitted it, started the motor, same problem. No smoke at all, but appears to be slightly rich. But then it clea
#13 Posted : Monday, 9 August 2004 5:52:39 AM(UTC)
Hi Raistlin, A couple of other things to try would be: 1. Take the plug leads off the plugs, remove no 5 plug after it has been sitting overnight and spin it over. in my case it expelled a little water out of the plug hole. 2 Have you tried a new lead on
#14 Posted : Monday, 9 August 2004 7:29:58 AM(UTC)
Hey 6pak, thanks for the input to you all, buttt,,,
removed plug, pressurised cooling system overnight, spun the motor over,,NOTHING....started the motor, same problem. Actually renewed the plugs, leads, cap and rotor. Same problem,,,damn!!!!
#15 Posted : Monday, 4 October 2004 10:06:01 PM(UTC)
Hi Has anyone mentioned a vacume leak where the manifold bolts to head ie intake gasket, that can cause a cylinder to drop out on idle but when under power will come good not the most common thing to happen but it does happen from time to time. dont know
#16 Posted : Sunday, 3 April 2005 9:38:16 PM(UTC)
sounds like water is leaking into number 5 cylinder.how about you remove all spark plugs from the engine pressure test you cooling system for a least 30mins then turn the engine over and see if any water comes out of anyof the cylinders.
#17 Posted : Tuesday, 5 April 2005 10:04:33 PM(UTC)
Have you Check to see if the coil is firing on #5 when it's cold?
