#1 Posted : Wednesday, 3 November 2004 11:04:57 PM(UTC)
Hi Guys, I seem to have a problem with my XC GS air vents. I cannot get any fresh air from outside to come through the vents? Seems only screen vent is working. The car has air con controls but the compressor is off the car.Manual says to have controls on the max or fresh position which i have.A mate says there are some vacuum lines that need to be connected for the vents to open?Can anyone tell me were and what they could be? Any help appreciated.
#2 Posted : Thursday, 4 November 2004 9:23:11 PM(UTC)
As is my understanding, the fresh air comes in via the plenum area, under the mesh bit where the wipers sit. To get the fresh air to work you need to pull the vent levers out, ( on the kick panels in the XC, I can't remember about the dash area) this wi
#3 Posted : Thursday, 4 November 2004 10:34:48 PM(UTC)
Paul, yes i have the vent knob pulled out from the kick panel and i even removed the grill were the wippers are to clean inside the plenum area but still no luck.
#4 Posted : Saturday, 6 November 2004 1:51:46 AM(UTC)
In XCs with factory integrated (Selectaire) air conditioning, the vent doors are VACUUM operated. Except for the one to the driver's footwell which is flap and cable. You need to have a vacuum hose connected to the brake booster fitting at the back of the
#5 Posted : Monday, 8 November 2004 10:36:08 PM(UTC)
Thanks Bill,It sounds like thats the info i need. I looked at the back of the motor and the only vacuum leads i could see where to the power brakes and the auto vacuum modulator.Would you be able to email me the info? thanks. [email protected]
#6 Posted : Saturday, 23 April 2005 8:50:11 AM(UTC)
fix vacume hose under dash one must have hole in it
Guest (5)
This page was generated in 0.094 seconds.
