#1 Posted : Tuesday, 16 November 2004 3:53:57 AM(UTC)
Hi all would anyone out there know what the timing is for an 88 ea falcon Thanks (its not multi point)is there any difference between the two ?
#2 Posted : Wednesday, 17 November 2004 6:45:14 AM(UTC)
Hi Smiley, my workshop manual states that it is 10 degrees BTDC. It doesn't differentiate between MPEFI and EFI engines so I assume they are the same.
#3 Posted : Wednesday, 17 November 2004 6:45:35 AM(UTC)
#4 Posted : Friday, 19 November 2004 9:23:51 AM(UTC)
You need to earth the diagnostic link to put the engine into base idle before you adjust the dizzy. the diagnostic connector can be found near the brake master cylinder. there are two connectors. Earth the single wire connector and if done correctly the e
#5 Posted : Friday, 19 November 2004 9:24:05 AM(UTC)
#6 Posted : Friday, 19 November 2004 9:54:49 AM(UTC)
thanks 6pak and the other unnamed helper.
Guest (6)
