#1 Posted : Thursday, 6 January 2005 7:18:28 AM(UTC)
OK long story, old pressure plate is buggered and my local parts blokes are gonna spin me a deal to get a twin plate clutch kit for the price of a single plate at retail price. I have no idea what year 302 clevo flywheel it is as engine was created from several before I actualy got it. I ordered a '79 unit as that is the year of my falc (XC). When I opened it I noticed that it only has 3 bolts to hold it to the flywheel and I remember when I put a new clutch plate in mine it had 4 bolts. There were lots of diferent holes but so I'm assuming they bolt into diferent holes. Are there any differencs in clevo flywheels that will prevent this twin plate from being fitted with ease?
Need vehicle on road by tomorrow arvo if possible
THANKS HEAPS
#2 Posted : Friday, 7 January 2005 9:37:02 AM(UTC)
I've also responed to your thread on network54. There shouldn't be any issues whatso over. As your current flywheel has 6 holes/threads the twin plate will only use 3 of the 6 there.
It wouldn't hurt to take your flywheel out and check it either as
#3 Posted : Monday, 10 January 2005 12:47:29 AM(UTC)
Thanks just wanted to know before I took it off the road that it was gonna fit. Clutch is now in and working fine.
#4 Posted : Saturday, 23 April 2005 8:44:15 AM(UTC)
to stop presser plate going again check cluch pedal travel they can go to far and do plate had 3 go before found promblem
#5 Posted : Friday, 6 May 2005 2:45:09 AM(UTC)
You've already fitted it so it won't be a problem for you, but I have a reco flywheel that came out of an XD and it doesn't have the holes for the twin plate.
The 302 single plate job bolts on but it's 1/2 inch bigger in diameter.
