#1 Posted : Monday, 3 May 2004 2:48:36 AM(UTC)
Can anyone tell me the size difference between VL turbo discs and VS Commodore discs in diameter and thickness? I have been told that VS calipers will bolt onto HQ stubs but the HQ disc is to small, however the VL turbo disc has the same bearings as the HQ and will fit straight on. Is this information accurate?? I guess i'm really asking can I put VL turbos discs with VS calipers onto HQ stubs without any modification?? Cheers Waz.
#2 Posted : Monday, 3 May 2004 11:17:35 PM(UTC)
The VR & VS front calipers are essentially the same as the VL turbo (and VL V8 and VN-VP V8 and VP s2 all models) ones except they don't need specific inner & outer pads like the turbos.
The disc is the same size - 289mm x 28mm.
#3 Posted : Tuesday, 4 May 2004 5:43:05 AM(UTC)
Cool thanks for the info. Anyone know if the rest is true, will
VS calipers fit onto Hq stub axels??
