#1 Posted : Monday, 3 May 2004 9:11:29 PM(UTC)
what chassis strengthening must be done to fit a 454 to a hz s/wagon. where are the weak points etc.?
#2 Posted : Tuesday, 4 May 2004 4:01:07 AM(UTC)
You need to have this answered by the certifying Engineer. But basically i've been told by an Engineer that you need the HZ/WB strengthening bars. HAve a look under a WB Statesman. They go from the crossmember to the rails under your feet. Bolt on.
#3 Posted : Tuesday, 4 May 2004 6:26:47 AM(UTC)
#4 Posted : Tuesday, 4 May 2004 6:27:27 AM(UTC)
#5 Posted : Wednesday, 5 May 2004 9:30:01 PM(UTC)
thanks guys! am getting other fabrication work done so I'll probably end up getting a chassis fabrication place to do the work. But atleast I have an idea wahts required now.
Looks like LPG is going to be the go. I havn't talked to the engineer yet, bas
Guest (6)
This page was generated in 0.159 seconds.
