#1 Posted : Tuesday, 11 May 2004 4:39:13 AM(UTC)
I'm considering changing from 3.55 to 4.11 in my HZ Tonner fitted with an RB30 to take full advantage of the overdrive and lockup converter.At the moment with 3.55's it cruises in top gear at very low revs,too low in fact for the weight and brick aerodynamics of the Tonner and 4.11's it seems would be a way to improve this and give better acceleration to boot.Does anybody have a set of good 4.11 gears for a Salisbury and also does anyone know what speedo drive gears are available for the VL nissan auto.Thanks
#2 Posted : Tuesday, 11 May 2004 5:53:41 AM(UTC)
Hi Carl
The only ratio you can get in a
Holden Large Salisbury close to what you want is 4.44.
You can find these gears in most 6 cylinder manual 1 Tonners.
Can't help you with the speedo gears, but they might be the same as some other sma
#3 Posted : Wednesday, 12 May 2004 5:54:13 AM(UTC)
I've got a 4.44 salisbury to suit a ute/ tonner if your looking for one. Located on the NSW south coast. $ negotiable. I've got a 2.78 too if anyone is looking for one !
Claude...
themurrays47 at bigpond.com
#4 Posted : Thursday, 13 May 2004 10:46:19 PM(UTC)
Thanks for the replies.I thought there was a 4.11 ratio as well but it looks like your right Dr Terry,4.44 is the next jump which may be to much,i'll have to work out wether it will be ok.I'm thinking that 4.44 gears should be easier to come by than a wh
Guest (5)
