#1 Posted : Wednesday, 12 May 2004 1:50:26 AM(UTC)
I have a vt ss with the 5lt v8 and my key stud is stuffed
It wont start anymore.
Is there anyway to start the car by bypassing the pcm system. Holden mechanics said you have to get a new key stud.
I dont wont to get key stud. because i have to get a new body control module.
SO does anyone know how you can start the car.
The car is a vt ss 5lt v8 195kw
JUSt put in a steering rack,and pump. It had a blown head gasket put in new gasket and had the heads reground.
#2 Posted : Wednesday, 12 May 2004 4:18:51 AM(UTC)
You can wait 1hr45mins with accessories on until dashlight stops flashing then start car,when you turn it off you leave it on accessories and disconnect battery
#3 Posted : Wednesday, 12 May 2004 4:31:13 AM(UTC)
Hi rock.
You don't have to replace the body computer just to replace the key pad.
New key pads are $40 to $60 depending on model, but you do need the dealers tool to code it.
In most cases the job is change from $100 including the new ke
#4 Posted : Wednesday, 12 May 2004 5:52:19 AM(UTC)
Thanks GTR5lt Ill try leaving laeving it on accsesories for 1 hr 45 minutes. Then hopefully it will start. Thanks Dr Terry I will take it to dealers and get a new key pad fitted and installed.
Thanks heaps for all your professional help.
