#1 Posted : Wednesday, 19 May 2004 9:46:50 AM(UTC)
hi
just wondering if anyone has used a V6conversions wiring loom for VS into HX 5.0L or a castleauto Wiring loom, is there much difference from the standard VS loom, or is it alot easy to use one of theres. thanks anyone for your help.
#2 Posted : Wednesday, 19 May 2004 7:31:49 PM(UTC)
probaly the easiest way to do it is to use a Kalmaker "Powerhead" harness, you need the engine harness from an efi motor, then this thing plugs inbetween the engine harness and the ecu (i think) then you only need to hook up 4 wires.
here
#3 Posted : Saturday, 22 May 2004 9:20:19 PM(UTC)
The standard harness is quite a neat fit into Kingswood any competent Auto elec can wire it up,the loom from Castlemaine is quite expensive when you consider a brand new engine loom from Holden is less than $200..let alone what a second hand one costs.Its
godfather Offline
#4 Posted : Sunday, 9 October 2005 9:31:26 AM(UTC)
godfather
can you give me that website address
HZ-GED Offline
#5 Posted : Sunday, 9 October 2005 9:20:21 PM(UTC)
HZ-GED
Do you have any details of what you had to do retrox? I am looking at doing one myself and some instructions would be handy. Do you have the wiring diagram of the injected loom variations?
Regards;
Ged
Guest (5)
