#1 Posted : Friday, 28 May 2004 5:52:00 AM(UTC)
whats the best way to get old window tinting off the windows. Can you get someting to make it easier to get off or something. Can anyone help.
#2 Posted : Friday, 28 May 2004 6:33:06 AM(UTC)
Try putting some small holes in the tint then spray with water and cover with glad wrap over night. Sounds like baking a cake. but it has worked for me.
#3 Posted : Friday, 28 May 2004 6:39:15 AM(UTC)
Try putting some small holes in the tint then spray all over the window with water and cover the hole lot with glad wrap over night. (Sounds like baking a cake). This seems to soften the tint. You will still have to scrub the glue off with metho but I hav
#4 Posted : Friday, 28 May 2004 6:52:33 AM(UTC)
I just used one of those one edged hardback razor blades took about 10 minutes to scrape it off.
#5 Posted : Friday, 28 May 2004 7:50:49 AM(UTC)
I pulled some of the other week and it pulled right off in 1 piece after starting it off with a razor blade. I then washed the gum off with thinners.
#6 Posted : Wednesday, 2 June 2004 7:44:09 PM(UTC)
I used a hair dryer to heat the tint up, then once I got an edge off with a blade, it peeled straight off...
Guest (5)
