#1 Posted : Wednesday, 2 June 2004 5:06:55 AM(UTC)
Has anyone changed their own ball joints on their car,I,m rebuilding my front end and woudn,t mind a few pointers,such as getting the old ones off and attaching the new ones.thanks.
#2 Posted : Wednesday, 2 June 2004 5:40:22 AM(UTC)
i forgot who wrote this, it was someone on oldholden.com, i just saved it incase i needed it one day.
1. jack up front of vehicle and place on stands.
2. remove road wheels. (loosen nuts before you jack it up)
3. remove the split pin from the lo
#3 Posted : Wednesday, 2 June 2004 8:14:03 AM(UTC)
Also helps if you have a gas or oxy torch to heat the hub surrounding the ball joint as this will crack the seal due to expansion of exterior metal being hotter than the ball joint pin. Suggest 10-20 second bursts followed by a good wack with the bfh...
#4 Posted : Friday, 4 June 2004 4:29:08 AM(UTC)
That would be me. Hope it makes sense.
#5 Posted : Friday, 4 June 2004 4:58:42 AM(UTC)
Thanks all,I,ll be on it this weekend
#6 Posted : Saturday, 5 June 2004 6:42:27 AM(UTC)
You don't need to touch it with oxy until you get the wishbone off to do the upper bushes. The lower wishbones don't usually need doing. Do all as above, you only need to undo the nut a couple of turns. Put a jack underneath supporting the nut when it all
sandman77 Offline
#7 Posted : Tuesday, 4 April 2006 7:54:04 AM(UTC)
sandman77
I think my ball joints might need doing , Do they clunk now & then when you turn corners ,does that mean they need doing?
Rusty B
#8 Posted : Tuesday, 4 April 2006 8:21:28 AM(UTC)
Probably, Rusty.
A better way to check is to chock the back wheels, jack up the front so the wheels are off the ground a few inches and pointing straight ahead. Put jack-stands under the front chassis and lower the car onto the stands.
Make sure you
sandman77 Offline
#9 Posted : Tuesday, 4 April 2006 8:25:52 AM(UTC)
sandman77
I'll give that a go on the weekend ,
Cheers bud
Rusty B
Guest (5)
