#1 Posted : Saturday, 12 June 2004 5:24:33 AM(UTC)
Does anyone know what i need to change the accelerator linkages on a 253 from a hq as i have installed it in my hz one tonner which was a six cylinder and is set up with a cable accelerator pedal.Any advice appreciated thanks.
#2 Posted : Saturday, 12 June 2004 8:26:03 AM(UTC)
I did the change to fit EFI to my Q.
You need the accelerator pedal, the pedal base, the cable and a couple of washers about 25mm.
The pedal out of about a HJ is best as the later model ones have the base welded to the floor, the earlier ones have the b
#3 Posted : Sunday, 13 June 2004 3:32:41 AM(UTC)
Remove the linkages from the carb....buy a longer v8 cable as they run around the front of the carb....also get a cable holder for infront of the carb...these bolt straight into the manifold....post up your e-mail addy and ill post u some pics if u like..
#4 Posted : Sunday, 13 June 2004 6:36:47 AM(UTC)
I have just changed from linkage on my HQ sedan to a HZ cable from a 253 .It is as johnperth describes but we found it easier to remove the booster to access the triangular plate on the firewall . Don't forget to put some sealer behind your new triangular
#5 Posted : Sunday, 13 June 2004 7:13:00 AM(UTC)
Kev,what you describe is exactly what i need.Some pics would be great,thanks,,,bammos at froggy dot com dot au with the obvious changes.
#6 Posted : Sunday, 13 June 2004 8:03:44 PM(UTC)
U have mail michael,melbourne ....pics are on their way..
Kev
This page was generated in 0.153 seconds.
