#1 Posted : Sunday, 13 June 2004 9:41:12 PM(UTC)
hi, just thought id check is it possible to swap the control arms and stub axles from a hr front end and put them onto the eh front end or not? thanks
#2 Posted : Monday, 14 June 2004 3:43:33 AM(UTC)
#3 Posted : Monday, 14 June 2004 3:44:24 AM(UTC)
#4 Posted : Monday, 14 June 2004 3:48:59 AM(UTC)
Hi Guys.
Yes, the upper & lower HD/HR arms will fit the EH crossmember. The problem is that the camber will be a mile out (too positive) & you will have no way of adjusting it.
That's why you use the HD/HR ball joint front end.
R
#5 Posted : Monday, 14 June 2004 6:09:24 AM(UTC)
thanks dr terry i thought as much thought id check
#6 Posted : Monday, 14 June 2004 6:10:09 AM(UTC)
#7 Posted : Monday, 14 June 2004 6:51:09 AM(UTC)
This page was generated in 0.147 seconds.
