#1 Posted : Tuesday, 15 June 2004 11:22:03 PM(UTC)
Hi all, just curious wether an airflow meter from a VL is the same or will work on a VK EFI engine?
#2 Posted : Tuesday, 15 June 2004 11:46:22 PM(UTC)
The VK uses a vane airflow meter - which is basically a spring loaded flap that is deflected via the incoming air.
I'm not sure that the VL uses this system.
The outputs would most probably be different in their reference - I'll check it out tonigh
#3 Posted : Wednesday, 16 June 2004 2:17:55 AM(UTC)
That would be sweet!
Thanks heaps
Dre
#4 Posted : Wednesday, 16 June 2004 2:31:43 AM(UTC)
VL uses a hot-wire airmass sensor. VK uses the vane/flap style. Totally incompatible.
#5 Posted : Wednesday, 16 June 2004 2:32:34 AM(UTC)
Guest (6)
This page was generated in 0.137 seconds.
