#1 Posted : Thursday, 17 June 2004 9:02:18 PM(UTC)
I have an EH which I usually try and use at least once per week. It is completely original,my question is,Is this enough usage to keep the car in good condition,when I use it use can vary from a quick 10 minute drive the the shops to 3 hour drive.
I am just worried that under useage may lead to problems.
#2 Posted : Friday, 18 June 2004 9:21:38 PM(UTC)
Once a week or fortnight will be fine so long as the drive is enough to warm things up properly. That way any condensation in the motor (especially during winter) is evaporated. The battery will last longer too if it's used, they don't like being idle!
#3 Posted : Monday, 21 June 2004 6:53:21 PM(UTC)
In cold countries a lot of people store cars away for the winter each year without too much problems, so your usage is a lot more regular than this!!
#4 Posted : Saturday, 26 June 2004 5:05:12 AM(UTC)
You should always drive your car warmed up for at least 20 minutes. This will heat up the oil enough to burn away the carbon toxins which build up.
Too many small trips and the oil becomes polluted very quickly which leads to engine wear.
Guest (6)
