#1 Posted : Monday, 21 June 2004 4:55:23 AM(UTC)
have an eh special wagon 100% original jumps out of third gear when foot taken off accelerator have heard many theories on the matter thought i would try here -box rebuilt 3000 miles ago and was the same then as now.
#2 Posted : Monday, 21 June 2004 7:44:56 AM(UTC)
Obviously not rebuilt properly. Take it back, thye have not fixed the problem you put it in for. But these boxes are dead easy to fix. Get a shop manual if you have no warranty.
Probably baulk rings. Try WWW.AUTOMATICTRANSMISSION.COM.AU/ORTO.ASP
He is v
#3 Posted : Tuesday, 6 July 2004 12:26:39 PM(UTC)
SYNCHRO CONE IS GONE, IF YOU DECIDE TO PULL IT DOWN URSELF, TAKE A LOOK AT THE BRASS CONE, THE TEETH SHOULD B 4 SIDED WITH SQUARE EDGES, IF ITS WORN THE TEETH WILL B ROUNDED. IF THATS THE CASE THE CHEEPEST WAY WOULD BE TO GET A GOOD SECOND HAND UNIT OUT O
This page was generated in 0.131 seconds.
