#1 Posted : Friday, 9 July 2004 7:02:32 PM(UTC)
A friend of mine scored a 50000 km VN ex cop car...not a chaser but must have been a detectives car or the like..its a V6 auto but none of the dash lights work except for 1 that shines down thru a tiny slit...just enough to see the speedo.
I assume chasers are setup similar but I'm wondering if anyone knows where they cut the wire or do they just pull the bulbs out or what did they do?
I was hoping to be armed with a bit of info before I pull the dash out.
#2 Posted : Saturday, 10 July 2004 12:31:50 AM(UTC)
I assume you've already done this, but have you checked the fuse?
#3 Posted : Saturday, 10 July 2004 6:05:06 AM(UTC)
Yes I have
#4 Posted : Saturday, 10 July 2004 4:53:27 PM(UTC)
VN dashes would have to be the easiest dashes to pull out.
Just unscrew the 2 self tappers up under the dash fasia at the top, and the 2 under the wiper & light switches.....and just pull the fascia off.
Next undo the self tappers that hold the dash
#5 Posted : Sunday, 11 July 2004 6:52:21 AM(UTC)
And also check for a dash light turn off switch as these were fitted in later series cop cars but not sure with VN.Turns off the dash lamps but leaves that one speedo light on
This page was generated in 0.104 seconds.
