#1 Posted : Tuesday, 27 July 2004 7:50:55 AM(UTC)
VK injected motor with manifold, computer and distributor for sale.
Manifold has corrosion near the exhaust recirculation port and needs welding. There is no pipe for the recirculation.
The motor has been stripped but is now loosely reassembled so I don't lose the bits, can be pulled down for inspection.
The pistons are good, and the bores still show the hone marks so would appear to have not worn the rings in.
I would replace the rings and bearings. The mains are fair, but the big ends are showing some copper so both should be replaced. The motor was reconditioned about 30,000k according to the guy I got it off. It has 30 (I think) thous pistons and 10/10 crank.
The head appears ok but I broke one of the water pump bolts so that need to be removed and rethreaded.
Has VK sump and oil pickup but can provide HQ or similar if required.
Has rocker cover.
I do not have any other parts for it.
I am clearing out a lot of my Holden stuff as I need the room for a new project and the cash.
If you want I can reassemble the motor with your parts.
$200 the lot or will consider separate if the price is right.
JOHNPERTH AT EMAIL DOT COM
Substitute @ and . where necessary, and no spaces.
#2 Posted : Wednesday, 1 June 2005 1:47:47 PM(UTC)
im interested in the motor i live in morayfield qld is it possible for delivery? please email me the details [email protected]
#3 Posted : Thursday, 2 June 2005 10:18:48 AM(UTC)
Sorry mate it was sold ages ago. I should have noted here that it was sold but forgot.
