#1 Posted : Wednesday, 11 August 2004 6:32:45 AM(UTC)
*****URGENT***** Need info on dimensions for V8 and 6 cylinder clutch pedals to suit WB only.
PH: 0418 945 875
#2 Posted : Wednesday, 11 August 2004 5:06:21 PM(UTC)
Can't give you 'dimensions', but V8 pedal bolts into the bottom hole and lines up perfectly with the brake pedal at the bottom. The 6cyl pedal is longer and bolts into the top hole. When the 6cyl pedal is put in the bottom hole it hangs about 20mm lower t
#3 Posted : Thursday, 12 August 2004 12:58:57 AM(UTC)
Just wondering, why is the 6 cyl WB pedal longer than all the rest?
Kingswoody
#4 Posted : Thursday, 12 August 2004 4:29:14 AM(UTC)
Hi Guys.
It's not just WB 6 cyl, it's also late HZ 6 cyl that is longer than the rest.
The reason is because they use the Commodore type pull fork linkage & bellhousing & fork,unlike all the others which have rat trap or half cable set
#5 Posted : Thursday, 19 August 2004 8:15:53 AM(UTC)
Dr Terry is correct about late HZ being the same as WB. I always refer to these as WB. The reason is that a different ratio is required for the V8 than for the six - the V8 needs more travel, hence the V8 pedal is shorter on the bottom, and longer on the
#6 Posted : Friday, 20 August 2004 12:18:07 AM(UTC)
thanks all, big help.
