#1 Posted : Saturday, 11 September 2004 4:32:33 PM(UTC)
The vacuum hose that leads from the ball reservoir at the front of the VN to the firewall, has a T piece located approximately adjacent to the distributor.
Can anyone tell me what should be connected to the hose at the T piece?
Totally rebuilt the car, and the only thing I can't seem to complete is this vacuum hose...it's driving me nuts!!!
Any help much appreciated.
#2 Posted : Saturday, 11 September 2004 7:12:30 PM(UTC)
Hi Bruce - that's the vacuum accumulator/reservior for the heater & A/C controls.
Basically you have a vacuum hose off the manifold, via a one way check valve, that then plugs into the T piece.
The 2nd leg of the T as you have already ment
#3 Posted : Monday, 13 September 2004 4:57:43 AM(UTC)
Found it Mick!
The connection is UNDER the brake booster vacuum hose where it connects to the inlet manifold....right where nobody would find it if they weren't in the know :-(
Thanks for your help.
#4 Posted : Tuesday, 14 September 2004 11:16:52 AM(UTC)
No worries mate, glad it's all sorted.
Got your email & I went out checked the VS to see if it was similar & I thought I'd have a look here before replying!
