#1 Posted : Tuesday, 14 September 2004 6:35:40 AM(UTC)
just put s/hand 202 in ute and am running on U/L fuel , i have been told i will need to retard timing to get it to run well , Is this true and if so how far will i have to retard it !! i have electronic ignition , does this make a difference
#2 Posted : Tuesday, 14 September 2004 8:15:25 AM(UTC)
Depends if high or low compression head. Running on standard unleaded will kill your motor if timing not adjusted, and if high compression it may be too high anyway. Depends on state of motor, best to test drive and retard as testing shows.
