#1 Posted : Monday, 20 September 2004 6:31:48 AM(UTC)
I have acabon canister on my 202 HJ. The carbon canister has 4 pipes on it and the rubber in the Purge valves is totally stuffed does anyone have any idea where I could get an new one? I'm in Victoria.
Most of the Carbon canisters I have seen have on had 3 pipes coming out of them any idea why mine is different? Any Ideas would be great.
#2 Posted : Monday, 20 September 2004 7:49:32 AM(UTC)
Looked it up in my Gregory's, it says The outside large one goes to carb top cover valve, next large goes to fuel tank vent pipe, next little pipe goes to intake manifold PCV pipe, little outside pipe (on purge valve) goes to carb distributor advance take
#3 Posted : Monday, 20 September 2004 12:03:06 PM(UTC)
Howdy,
Easy fix, I've done it and it works great. The 6 cyl XF falcons have a purge valve that is external to the cannister (it is disc shaped and has 3 hoses - two are the switched vacuum i.e vacuum between the canister and the engine that you want
#4 Posted : Monday, 20 September 2004 12:03:49 PM(UTC)
Howdy,
#5 Posted : Tuesday, 21 September 2004 3:24:20 AM(UTC)
Thanks Guys I'll give it a go.
#6 Posted : Saturday, 9 October 2004 7:52:04 AM(UTC)
i have the part you need it is new and still in box i live in melb
#7 Posted : Saturday, 9 October 2004 7:57:35 AM(UTC)
i have the part you need it is new in box live melb
