#1 Posted : Tuesday, 21 September 2004 10:26:29 PM(UTC)
Hi all, does anyone know if there are any differences between a HZ guard and WB guard *apart* from the fact that the WB guards have the front bottom bit cut off???
Cheers Dre
#2 Posted : Wednesday, 22 September 2004 5:50:09 AM(UTC)
The only difference is the bottom cut off
#3 Posted : Wednesday, 22 September 2004 6:09:11 PM(UTC)
Guards are also different in a few other places. 1. At the top front where the WB nose piece bolts on. HJ-HZ guards don't have a bolt hole there. 2. WB statesman guards have a threaded hole on the side where the eyebrows attach. 3. The holes on the the
#4 Posted : Wednesday, 22 September 2004 10:21:15 PM(UTC)
NICE :) so you can convert them then!
Thanks for the info...
Cheers Dre
#5 Posted : Friday, 24 September 2004 8:40:47 AM(UTC)
The iner guard screw holes must be different also because I tried fitting a pair of WB stato wheel arch trims to a HZ guard and some of the top holes where way out.
#6 Posted : Friday, 24 September 2004 6:29:31 PM(UTC)
Yes they are different there also, but normally people use the WB inner guard when they fit a WB front to an earlier car, or use the HJ-HZ inner when using an earlier guard modified into a WB one. The inner guards are different also as far as bolt holes f
