#1 Posted : Friday, 24 September 2004 7:38:52 AM(UTC)
Just stuck a blue V8 dizzy into the red 308 in my HZ tonner. In the process discovered a little trick. When attempting this, throw away the big, expensive standard 2-piece dizzy cap and rotor button. All you need to do is leave the original dizzy cap and leads on the engine as it fits the electronic dizzy. All you need is an XD/XE Ford Cleveland rotor button. Simple as that. The only other bit you need is an extra spark plug lead as the tip of an electronic dizzy 12V coil looks like a spark plug and the red motor coil lead doesn't fit. And of course you need to bypass the in-harness resistance for the coil supply. The problem I found with using the bigger dizzy cap is it fouls on the manifold vacuum brass attachment, and you can't get much adjustment on the distributor as a result.
#2 Posted : Friday, 24 September 2004 8:03:46 PM(UTC)
u may have to watch out for crossfiring or tracking in the smaller cap. I was led to believe this was the reason they used the larger cap. maybe more a problem if u run lpg as well.
hope it works tho ;)
#3 Posted : Saturday, 25 September 2004 2:11:32 AM(UTC)
I always wondered why they used the big cap. The small size cap was used on the 6-cylinder engines and wasn't a problem on other V8's eg Cleveland. I thought it might have been a cosmetic thing, or even a carry over from the Chev HEI style dizzy with the
#4 Posted : Saturday, 25 September 2004 5:53:33 AM(UTC)
Howdy,
It's been proven on the dyno that the small caps on the HEI (ie adapted as Byron did) provide better performance. The book "How to Rebuild & Hotrod Holden V8" by Ellerys' even has a section about just this on pages 196-197. It g
#5 Posted : Saturday, 25 September 2004 4:48:35 PM(UTC)
Must be some truth in what Paul and Byron are saying....my 5 litre VN engine, and the VR HSV GTS 5.7 litre V8 we have at work, also have small cap distributors. There's no room for a large cap distributor in a fuel injected V8 anyway!
I'm sure GMH would
#6 Posted : Saturday, 25 September 2004 6:17:56 PM(UTC)
I have a large dizzy cap (Commo elec. dizzy) but I am sure it is a one piece.
Are these easy to get?
so the inter
Guest (5)
This page was generated in 0.126 seconds.
