#1 Posted : Friday, 1 October 2004 7:16:58 AM(UTC)
Can someone tell me what is the latest model/year ute that we can bold a HQ prem front to ? are the door lines etc compatable ? tah
#2 Posted : Friday, 1 October 2004 10:25:25 AM(UTC)
HQ front panels are, basically, one on their own although they will physically bolt onto later models, they do not line-up well.
For example: The "bump" that runs along the middle of the guard, ends behind the nosecone on HJ - HZ guards bu
#3 Posted : Friday, 1 October 2004 6:08:01 PM(UTC)
If you have the whole front clip it would bolt on to HZ/WB but the bonnet top shape wont match the panel in front of the windscreen , this could however can be changed with a rarespares section welded in, replacing the old windscreen panel.
#4 Posted : Saturday, 2 October 2004 2:23:32 AM(UTC)
The HQ Prem front (nose, guards, bonnet, bumper) will fit all HQ's. It will also fit all 1-tonners HJ-HZ, except for the HZ Ambulance which has a HZ Premier front (I'm not 100% sure what HJ/HX Ambulances had on them). The HQ Prem front will also fit onto
