#1 Posted : Tuesday, 12 September 2006 7:27:06 PM(UTC)
G'day guy's,
Suspension time for the EH. Just seeing what others are running and what brands I should be looking at (running a HR front end with a V6)
Up north here I only have Fulcrum or Pedder's. So far Fulcrum can supply Munro shocks for $130 and new spring's (standard hight)for $155. They can also supply Bilstein shock's.
Ped start at $220 for shock's and was told they only make a lowered spring? With some of the Pedder's shock's they said I would have to enlarge the hole in the bottom susp arm to fit the new shock in.
The Ute already has a 22mm Kmac sway bar but I don't have any link pin to the susp arm, anyone out there running the Kmac bar and what shape is the link pin? ie: is it straight or a "S" shape like the whiteline bars?
I'm looking at keeping it standard height and it will be a daily driver. Any tips for a nice setup for the front and is there any need to up the spring rates due to the V6??
Cheer's, Graham
life's to short not to be....
