#1 Posted : Sunday, 17 October 2004 8:59:14 PM(UTC)
All of a sudden my VR SS has started to shudder and run extremely rough under acceleration. You can feel the power cutting in and out really badly as you take off. Its sometimes worse than other times and sometimes it seems like the engine might cut out completely. I've had the car for over a year and its never skipped a beat until now.
I was thinking it may be a fuel problem but I'm not sure why its just started to run so bad. Its booked in for a service on Tuesday so hopefully they'll find out whats wrong with it.
#2 Posted : Monday, 18 October 2004 1:18:27 AM(UTC)
more than likely fuel. i had the same problem. ran ok just cruising but under any sort off acceleration it almost died. turned out to be the fuel filter so check that b4 it goes to the workshop. try some GOOD injector cleaner aswell just for good measure
#3 Posted : Monday, 18 October 2004 9:14:58 AM(UTC)
Yeah thanks, I've put some injector cleaner in. Fuel filter was replaced about 6 months ago but I guess they'll check that again for me.
#4 Posted : Monday, 18 October 2004 4:43:17 PM(UTC)
Hi Bubby.
Your problem is most likely ignition related.
Check your plugs (visually) & check your leads (with an ohmmeter) & then the coil.
We've had a lot of coil failures on VN-VS V8 in my workshop, & they're a mongrel to ac
#5 Posted : Monday, 18 October 2004 8:38:03 PM(UTC)
I agree with Dr Terry. Ignition !
I assume its OK on the flat or no load, but maybe on hills of accel it just looses it ?
Buy some genuine GMH leads. Its easy work, you wont have to pull anything apart, and you'll know straight away.
Rg
#6 Posted : Wednesday, 20 October 2004 5:18:04 AM(UTC)
Yeah got it serviced, turned out to be faulty leads. Car runs sweet once again ;)
