#1 Posted : Saturday, 6 November 2004 11:11:15 PM(UTC)
Ok folks I really have to move this stuff the ol shed is getting a bit cramped.....
<p>
HQ GTS guard.....LH Genuine.....small rust in bottom...very clean.....$180
HQ GTS guard.....RH HAD WELD IN SECTION FITTED...really good job on fitment of flutes....................$140
1 Pair of GTS Mirrors HJ-Z..........$150 the pair...
GTS Steering wheel.....no allen bolts with it ...but has GTS centre...good cond no cracks bends or breaks....has a bit of grain loss on the usual spots....VGC....$180
HJ-X GTS DASH...complete set of gauges...cracked fascia...repairable...comes with a few extras...$200
HQ GTS DASH ....gauges only....fuel/oil...tacho...speedo...amps/temp....and a clock....$120 the lot
<p>
14x7 and 14x8 aftermarket centrelines..suit HQ/J/X/Z WB..2 with tyres 2 without.......$200
Saisbury diff 3:36 ratio I think.... will check and update this.......$150 suit sedan/wagon/stato/coupe
M20 conversion suit V8 aussie pattern 253/308...comes with box, shifter, bellhousing, flywheel, rat trap clutch setup, all u need to supply is a clutch....box is a recent reco done about 10,000kms.......$300
3 sets of Heavy duty/lowered rear springs to suit sedan/wagon/stato/coupe....$20 a pair
pair of almost new chrome rocker covers suit 253/308..................$20
mechanical tailgate winder mech to suit a wagon.......................$10
HQ sedan rear bar in good cond...complete with lenses and loom, comes with spare lenses....$50
HJ/X/Z twin headlight radiator support panel...minimal rust...........$40
HJ/X/Z twin headlight radiator support...modified to have square headlights....comes with headlight and surrounds.....$50
HJ/X/Z twin headlight nosecone freshly painted in atlantis blue....see project one tonner in my shed for pics....just the nosecone nothin else......$60
HQ GTS wheel centre caps...Lion has no tail...fair condition...have 2....$20 each
HJ/X/Z GTS wheel centre caps...lion has tail....fair condition...have 2..$20 each
HJ one tonner rails....complete and rolling with fuel tank and a rebuilt front end (nolothane bushes and new ball joints, lowered springs) still has a sailsbury diff attached 3:55 ratio I think will check .........$350
hayman reese towbar to suit one tonner/ute/van....comes with tongue....big square slip in one....$50
<p>
Also have many other parts from HQ-J-X-Z drop me line with a query.....
If you dont like the prices...make me an offer by e-mail....
<p>
All parts are located in SE Melbourne pics can be posted if you require
Drop me a line on schmee(at)bigpond(dot)net(dot)au remove and replace as usual
<p>
Cheers Kev
#2 Posted : Sunday, 7 November 2004 9:45:22 AM(UTC)
Just how big is that bloody shed of yours.
#3 Posted : Sunday, 7 November 2004 10:12:34 PM(UTC)
Not that big at all Owen.....I just pack it pretty tight....lol....
Kev
#4 Posted : Monday, 8 November 2004 6:43:45 AM(UTC)
Hi Kev,
Did you check the ratio of the diff? Does it have disc brakes? Is it an LSD or open? Will it suit a WB Statesman?
Cheers.
#5 Posted : Monday, 8 November 2004 8:14:05 AM(UTC)
Heya Kris,
Checked it out...beleive it is a 3.36 open wheeler 10 bolt sailsbury...complete with drum brakes....will fit a WB, you can use your current brakes and axles to keep it a disc brake diff...
This page was generated in 0.066 seconds.
