#1 Posted : Monday, 8 November 2004 9:45:01 PM(UTC)
went to change globe in one brake light now nothing works. all ideas appreciated
#2 Posted : Tuesday, 9 November 2004 9:49:51 AM(UTC)
Nothing??
What did you actually do? Sounds like you have a dead short somewhere.
#3 Posted : Tuesday, 9 November 2004 8:12:43 PM(UTC)
didnt do anything other than fiddle with the globe now this morning the car wont start, going to have to save for an auto elec thanks though
#4 Posted : Wednesday, 10 November 2004 8:09:39 AM(UTC)
Won't start..Does it do anything, like crank and try to start, or won't crank,or sounds like flat battery? Symptoms?Try taking the globe out and see what happens. Maybe has tripped security system when fiddling with globe.
#5 Posted : Wednesday, 10 November 2004 9:58:41 PM(UTC)
All fixed battery corroded and tail light I didnt realize their was another lot of fuses under the steering wheel I am a blonde female and it show sometimes. I would like to know if u know how to reset the computer though Thanks 4 ur help
#6 Posted : Thursday, 11 November 2004 11:29:32 AM(UTC)
Being a blonde or female has nothing to do with it we all have to start somewhere.
#7 Posted : Friday, 12 November 2004 1:50:37 AM(UTC)
Right on John, hey remember you found the problem and fixed it, so you must be doing OK!!
Peter
#8 Posted : Friday, 12 November 2004 5:12:45 AM(UTC)
Sorry can't help with computer maybe address question to Dr. Terry?
#9 Posted : Friday, 12 November 2004 4:35:10 PM(UTC)
Hi Guys.
The only thing that should need 'resetting' is the radio PIN code. Which computer do you mean, or are you having other problems.
Dr Terry.
#10 Posted : Friday, 12 November 2004 9:13:45 PM(UTC)
The reason I want to reset the comp is the seat belt tensioner light is on and the clip that was broken is fixed now but Holden said the warning light wont go out until the comp is reset - have reset trip comp but that didnt work so any ideas dont want to
#11 Posted : Saturday, 13 November 2004 12:52:47 AM(UTC)
The way my manual says to reset the computer is with the ignition off, unplug it from the loom for at least 30 secs. Then just plug it back in and you should be right.
Cheers, Steve.
#12 Posted : Saturday, 13 November 2004 3:46:56 AM(UTC)
Hi Steen.
OK now I understand, it's difficult to know what is meant by resetting THE computer, when this is more than one of them.
The ECU that controls this is the Air Bag module, which will need a scanner (Tech2, hanatech or similar) to be r
