Samboy Offline
#1 Posted : Monday, 18 September 2006 11:12:22 PM(UTC)
Samboy
Hi Folks,
I had my carby reco'ed about a year ago, just the standard Stromberg. I took it off and put it back on myself, but it leaks a bit from underneath. Any ideas I could try before I take it somewhere and pay to get it fixed??
Thanks!
Sam
#2 Posted : Tuesday, 19 September 2006 10:43:57 AM(UTC)
Take it off and make sure the base of the carb and the manifold (where the carb mounts to) are both flat.
Replace the base gasket (between the carb and manifold).
Cheers...Dave
666 Offline
#3 Posted : Tuesday, 19 September 2006 6:45:35 PM(UTC)
666
Samboy,
You can also try sanding the base of the Carb flat on a peice of Glass to get rid of any warpage (usually caused by someone overtightening the bolts).
Some Hylomar spray on the Gasket helps and a bit of loctite on the threads when you redo the
666
