#1 Posted : Friday, 19 November 2004 3:16:25 AM(UTC)
has any one put a wb statesman diff into a wb ute?
any comments or direction would be very much appriciated.
tom
#2 Posted : Friday, 19 November 2004 3:45:28 AM(UTC)
#3 Posted : Friday, 19 November 2004 3:49:56 AM(UTC)
Hi TOM.
The are 2 main differences.
1. You will have to have the trailing arm brackets removed & 2 new leaf spring mounts welded to the diff housing, position & diff pinion angle is critical.
2. The Statesman's rear disc calipers
#4 Posted : Friday, 19 November 2004 3:57:13 AM(UTC)
thanks dr Terry
COULD YOU LEAVE THE TRAILING ARMS ON AND WELD A NEW BRACKET TO THE
FRAME? OR SHOULD I NOT BOTHER AT ALL.WOULD JUST LIKE DISC DRAKES ON THE REAR!
CHEERS
#5 Posted : Friday, 19 November 2004 3:58:09 AM(UTC)
thanks dr Terry
CHEERS
#6 Posted : Friday, 19 November 2004 10:44:26 AM(UTC)
You do not have to swap the entire diff assembly to worry about trailing arms etc just swap the brakes ,axles and any of the other stuff needed. But as mentioned the park brake bracket is a pain. Use lowering blocks to allow the bracket to clear the leaf
#7 Posted : Friday, 19 November 2004 6:51:16 PM(UTC)
many thanks some good advice
i will look in to the vn diff.
tom
#8 Posted : Friday, 19 November 2004 6:53:06 PM(UTC)
tom
