#1 Posted : Wednesday, 1 December 2004 11:43:29 AM(UTC)
Can anyone help with this idea? I'm fitting a 5L VS engine and auto to my WB Statesman and was wondering how hard it would be to set up the electronic cruise control to run in the WB. Would it be very hard to set up or easier to by an after market one? The VS donor car has cruise on it so I should have all the bits neededif i did it. Any help appreciated.
PS 24 sleeps til santa!
#2 Posted : Wednesday, 1 December 2004 5:07:50 PM(UTC)
If your doner car has all the bits, it's very easy to fit. Just swap all the bits over. The biggest problem I can see is speed sensing, which you will need anyway or your car stalls every time you pull up to the lights.
#3 Posted : Thursday, 2 December 2004 3:17:35 AM(UTC)
Hi Aaron.
If you're installing the complete V8 & auto, you've got just about everything you will need.
The only thing you will have to make up is the control unit.
A small plastic box or similar with one on/off switch & 2 momenta
#4 Posted : Thursday, 2 December 2004 6:04:38 AM(UTC)
Hi Dr Terry,
Ihave modified my a/c bracket from the WB and bolted it back onto the front of the LH head as on the blue motor. This means I can still use all the hoses and plumbing etc. I used a MAF hose off the XF efi engine with the tight ninety bend fo
