#1 Posted : Wednesday, 15 December 2004 4:40:31 AM(UTC)
hey
will a hk 6 cyl diff center fit into my hr diff housing will the splines be the same??
#2 Posted : Wednesday, 15 December 2004 8:10:23 PM(UTC)
Yes these banjo centres are interchangable as both should be for the course spline axles. Check the ratios though (written on the crownwheel) as you may wish to keep the same ratio.
Peter
#3 Posted : Thursday, 16 December 2004 3:22:13 AM(UTC)
thank you peter
is the v8 diff the same to
#4 Posted : Thursday, 16 December 2004 10:50:36 PM(UTC)
As long as it's a banjo centre and not a salisbury centre you will be fine to use it. 6 cylinder ones are usually in better nick as they haven't had the hard work like the V8 ones have had!!
Peter
#5 Posted : Friday, 17 December 2004 4:07:08 AM(UTC)
Hi Guys.
The V8 banjo has a different, larger yoke which takes the larger rear uni joint, but the axles are the same.
#6 Posted : Monday, 20 December 2004 11:10:49 PM(UTC)
I guess it would, thanks Doc!
Peter
