#1 Posted : Wednesday, 15 December 2004 6:56:39 AM(UTC)
Ok the story goes like this, i have a VN injection setup on the VK 308. i got told that i should put a knock sensor on it. Why? whats the advantage of this? where does it go and do i have provision to put one in? Cheers
#2 Posted : Wednesday, 15 December 2004 4:27:20 PM(UTC)
Knock sensor attaches to the right side of the block, just in front of the engine mount. There is a brass boss that unscrews, and you just screw in the knock sensor.
The lead from the knock sensor attaches to B11 terminal on your ECU.
I'm not sure in al
#3 Posted : Thursday, 16 December 2004 6:50:22 AM(UTC)
Thanks for the info. If it does pretty much nothing then there is no point spending $280 on a bit of plastic and a few wires. Might spend it on something worthwile
#4 Posted : Thursday, 16 December 2004 10:53:42 PM(UTC)
This is something I've been meaning to ask. Do you really *have* to mount the knock sensor on the drivers side? there is a coolant drain plug (that the sensor screws into) on both sides of the block so would it make any difference? I wouldn't have thou
#5 Posted : Friday, 17 December 2004 1:42:26 AM(UTC)
I don't think it matters Dre. My VS calais is a factory HSV enhanced 185i that's never been played with, and it has the knock sensor on the passenger side. The driver's side looks like the bung has never been removed.
#6 Posted : Friday, 17 December 2004 6:12:58 AM(UTC)
Interesting I have a VS111 stato 185kw (holden by design) and the sensors on the right side of the block down near the power steer!
#7 Posted : Friday, 17 December 2004 4:16:21 PM(UTC)
My VR's knock senor lead is a seperate lead within a grey plastic shield, that goes to the ECU.
I also have a VT V8 which has the knock sensor lead incorporated in the engine loom.
Both vehicles have the knock sensor on the drivers side.
I can't see it
#8 Posted : Sunday, 19 December 2004 4:52:35 AM(UTC)
The VT had the knock sensor wire in the main loom as they got them fitted as standard (along with roller cam etc).
The VN-VS 5L only got a knock sensor if it was a HSV or HSV enhanced (or done aftermarket).
On mine when you pull up the passeng
#9 Posted : Sunday, 19 December 2004 7:26:09 AM(UTC)
Hmmmm. Yeah, I guess that makes sense Mick.
