#1 Posted : Saturday, 25 December 2004 6:49:11 PM(UTC)
Dear Gary or Dr Terry and others,
Was wondering what your advice would be on my idea to put an EFI VN V8 into my tonner. I am wondering if the Tonners 2.78 Salsibury diff will be able to handle the EFI motor n T5 gearbox?? or Is a 3.08 salsibury a better option and why??
Pos1976
#2 Posted : Tuesday, 28 December 2004 8:07:54 AM(UTC)
HEAPS of these have been done, and it's a simple conversion, but probably the 2nd most difficult of these conversions is using the T5 (hardest is using a Getrag). However with a T5 it's still not difficult. A 2.78 is no weaker than a 3.08 as they're basic
#3 Posted : Monday, 10 January 2005 8:27:14 PM(UTC)
I've used 3.36 with the same conversion as you mention, and am very happy with that ratio.
Cheers, Steve.
#4 Posted : Wednesday, 26 January 2005 7:05:02 AM(UTC)
2:53 3:08 are both a higher ration diff and ive got a 3:08 behind a stroked 308 700 holley dual dizzy it does a good job.
#5 Posted : Tuesday, 15 February 2005 11:24:05 AM(UTC)
How did u go with the temp and oil pressure senders?
#6 Posted : Monday, 4 April 2005 4:24:52 AM(UTC)
Hey Guys,
l am attempting to install a getrag in a tonner and have hit a few snags,, the tunnel is not deep enough and the speed transmitter yoke will not attach to the box because the floor crossmember does not give sufficient clearance. Does anybody kn
#7 Posted : Monday, 4 April 2005 7:24:03 AM(UTC)
Hi Guys.
To answer the temp & oil gauge sender question. I'll assume you're referring to gauges.
The temp gauge sender is easy, just use the original One-Tonner sender (correct one for your model) in place of the Commodore sender, it's the same thre
#8 Posted : Monday, 4 April 2005 8:06:54 AM(UTC)
I used to have a WB 1-tonner, and the dude that bought it put a VN V8 and Getrag into it. He had to absolutely butcher the floor to make it fit, plus the stick was back too far. He also had to get an electronic speedo. I'd use a Supra box if you want a 5-
Holdenute Offline
#9 Posted : Monday, 4 April 2005 7:19:00 PM(UTC)
Holdenute
I've got a T5 in my HZ, but I'm using one from a 6cyl Falcon EA. Has a shorter input shaft, so the shaft doesn't go back as far. Still need to do some cutting of the floor though. On the oil presure senders, as Terry says, use a T piece and run both sende
Never late in a V8
#10 Posted : Sunday, 10 April 2005 8:51:26 PM(UTC)
Has anyone installed a Tremec TKO or 3550 into a HX-HZ ? What are the traps, ie: cutting the floor ?
Dylan Offline
#11 Posted : Sunday, 10 April 2005 9:33:36 PM(UTC)
Dylan
i have not done it, but the Tremecs have 2 or 3 different shifter positions, one of them should be fairly close to where you want it.
Guest (5)
This page was generated in 0.091 seconds.
