hainzy Offline
#1 Posted : Monday, 25 September 2006 3:15:37 AM(UTC)
hainzy
Hi all.
If you have the steering column from a HJ with the simpler HQ style indicator stalk, is it possible to change it to a newer HZ type of stalk? What are the problems with this conversion? Also this may be the dumbest question in the world but is a Turbo 400 a turbo pattern gearbox? Thanx
#2 Posted : Sunday, 1 October 2006 10:44:46 AM(UTC)
Hi Hainzy,
Yes, you can put an HZ Coffee Pot on on HJ column and use the HZ stalk. You will need to rearrange some of the wiring under the dash though.
Yes a T400 is a Turbo (or Chev) pattern box.
Cheers...Dave
hainzy Offline
#3 Posted : Monday, 2 October 2006 12:08:23 AM(UTC)
hainzy
Thanx Dave. Appreciate the info. Cheers.
