#1 Posted : Thursday, 30 December 2004 12:02:51 AM(UTC)
A work collegue has recently bought an FJ ute. Against my repeated criticisms he went out a bought a 350 Chev, TH400 and CRS chassis kit plus more. As you all guessed the engine is too big to register in NSW (301ci is the biggest allowed) - I'll help him to solve that problem with a 283 (which can easily be stretched to 327ci). But he needs a diff. A 9" is too big and heavy. Has anyone out there fited anything that is stronger than a banjo that is about the right width? I believe he is fitting Commodore discs to the front, so the stud pattern will probably have to be able to be modified to 120mm PCD. Volvo, Mustang, A9X?
#2 Posted : Thursday, 30 December 2004 5:08:23 AM(UTC)
byron, i am currently doing a V6 conversion into an fx sedan, i am running a shortened VN commodore diff,this is not only as strong as a 9" it has the commodore stud pattern and disc brakes.
i had this done by phil hutton (phils diffs and suspensi
#3 Posted : Thursday, 30 December 2004 5:53:21 AM(UTC)
Wouldn't a Vb-VK one be close to the same width as a FJ? Maybe offset the rims?
#4 Posted : Thursday, 30 December 2004 6:30:39 AM(UTC)
john,
i know people who have used these early commodore diffs, in fx/fj's
they do fit, but you have to run almost flat rims to get clearence under the gaurds, i found in my situation the shortened VN was better as i could adjust the width to centre the
#5 Posted : Thursday, 30 December 2004 9:26:03 AM(UTC)
About six years ago I had a crazy next door neighbour who fitted a 351 Cleveland and top loader into an EH. He used a V8 Commodore diff. I am not sure what model it was but it fitted without narrowing. It was still going well when he sold the car last
#6 Posted : Thursday, 30 December 2004 11:59:25 AM(UTC)
The EHs are pretty narrow when you think about it. I have seen a Morris Major (same as austin Lancer) with a EH back axle in. He had a hot motor and kept breaking Austin diffs, not surprising when they are basically the same as Morris Minor diffs!
#7 Posted : Thursday, 30 December 2004 5:37:30 PM(UTC)
Thanks Les. Wrong Byron though. What axles did you use? You can't respline Holden axles without re heat treating them.
#8 Posted : Friday, 31 December 2004 6:59:21 AM(UTC)
byron, sorry for the confusion, thought you were someone else.
to answer your question, i am running a shortened VN diff, using one original VN axle and one axle from an early 10 bolt salisbury V8 commodore diff, same splines and you dont have to shorten
#9 Posted : Friday, 31 December 2004 6:17:39 PM(UTC)
Clever. So I'm guessing you turf the VN long axle, swap the short one over to the other side and fit a Commodore 10 bolt axle into the vacant side? No stud pattern or flange size change either. Will investigate. Could you please email me the contact detai
#10 Posted : Saturday, 1 January 2005 1:00:06 AM(UTC)
Always a cunning stunt somewhere isn't there. Have to admire lateral thinking.
#11 Posted : Saturday, 1 January 2005 3:12:05 AM(UTC)
The easiest way to make a 9" diff fit a HQ-WB is to weld on the old Salisbury tubes, complete with mounts and guess what - VN axles are the right length, and have the right backing plates even. Commodore discs bolt straight on too. Never tought of mi
#12 Posted : Tuesday, 11 January 2005 5:30:17 PM(UTC)
diff guy in brisbane is phil, 0415 745 703, he also does v6 conversions and front ends at a good price.
