#1 Posted : Sunday, 9 January 2005 9:31:00 AM(UTC)
Thanks to the guys for your advice. Aaron the channel 2 (ABC) 7/9/10 are VHF, SBS and 31 are UHF.
Your point about the amplifier is noted. The reception for the UHF stations is poor, SBS I can just get colour in but its pretty spotty, 31 I can only get in B/W and no sound. The direction of the antenna is about the same as the neighbours but I am going to replace it anyway as it's 10 years old and pretty crappy at the box where the leads connect, also it is only about 9 or 10 elements so that won't help, and being only a mile from the ocean we get all the salty corrosion.
#2 Posted : Monday, 10 January 2005 8:07:51 AM(UTC)
try- www.hills.com.au
and go to the antenna section
#3 Posted : Monday, 10 January 2005 4:02:01 PM(UTC)
Ever think of buying a boat TV antenna?
....You could even take it home in the Mighty Boy :-)
#4 Posted : Tuesday, 11 January 2005 8:45:06 AM(UTC)
Why boat?
Mighty Boys go great!
#5 Posted : Tuesday, 11 January 2005 11:26:21 PM(UTC)
Boat/cruiser TV antennas work a little differently than standard house ones.
I would have thought that they may be set up to work in poor reception areas...
Just trying to think laterally
#6 Posted : Wednesday, 12 January 2005 5:16:50 AM(UTC)
Make sure you use co-axial antenna cable. It gives much better reception than that of ribbon cable, you may need to get a separate UHF antenna for SBS, you can also buy VHF/UHF combos.
#7 Posted : Wednesday, 12 January 2005 11:18:19 AM(UTC)
Well I bought a new antenna today it is supposed to be a medium-fring one as i didn't want to overpower it and have ghosting problems I get them anyway.
It has anade a big difference, can now get #! and also SBSand ch.2 are much clearer, still have to li
Guest (5)
