Rhys Offline
#1 Posted : Wednesday, 27 September 2006 4:12:08 AM(UTC)
Rhys
Hi all,
I've got an air cleaner from a WB Magnum - same as what was used for all the V8 HDT engines. I'm after the piping/tubing that goes from the snout to the drivers headlight area. Does anyone have or know of where to get this stuff from? Its to suit a WB commercial. I've seen a few HDT engine bays where this tube has been removed - is there any reason for this or would it be just because its in the way?
thank you
Rhys
#2 Posted : Wednesday, 27 September 2006 7:20:45 AM(UTC)
The magnum air cleaner is quite different to a HDT commodore one. The wide snout is rotated around to a different position, and they are very rough'n'ready!
From a post on BrockCommodores a while back, Chris Sewell, who worked for HDT in that era, not
Rhys Offline
#3 Posted : Thursday, 28 September 2006 9:39:58 AM(UTC)
Rhys
Mick, thanks for the info - when you say rough and ready, do you mean they were bigger in size than the HDT commodore air cleaners? I'll have to contact the Purple Pig to see if they can make something up, I guess it was a custom thing they made at the ti
